unkier wrote:next error )
it is occurs then i select my server and click login
That error is being a bit obfuscated by a bug in Twisted that's been fixed in their trunk, but in the Overseer GUI, did you hit the "Initialize" button. Definitely check out starting your own server in the user manual.
Acidz wrote:Thanks Alot!! Its all running very nice now... Used this and without any problems It started!.
Awesome! Glad you were able to get things going!
Also, fyi, if you are using the Panda client, you want to select the Panda Player character (which will be the second in the list). The first player it creates is in the Ogre3D world.
And another tip since I just mentioned it to Acidz on IRC... To connect to your new server, you have to adjust the client.conf to point at it vs the MV3D demo servers. To do this, change the following lines in client.conf:
- Code: Select all
[Player]
servers=pb://localhost:1999/Player
[PBClient]
loginServices=https://localhost:8080/service/
I'll update the wiki with that info a bit later.
