sudo apt-get -s install python python-twisted python-pyode python-wxgtk2.8
mike@server:~/mv3d/trunk$ cd mv3d/tools/overseer
mike@server:~/mv3d/trunk/mv3d/tools/overseer$ python overseer.py
File "mv3d/tools/overseer/overseer.py", line 65, in <module>
from mv3d.server.overseer import ChildServer
File "/home/demon/devel/mv3d_trunk/mv3d/server/overseer.py", line 38, in <module>
from mv3d.server.worldgen import WorldGenerator
File "/home/demon/devel/mv3d_trunk/mv3d/server/worldgen.py", line 36, in <module>
from mv3d.server.model.octree import OctreeArea
File "/home/demon/devel/mv3d_trunk/mv3d/server/model/octree.py", line 34, in <module>
from mv3d.util.conductor import RemoteException
ImportError: cannot import name RemoteException
acer@acer-tech:~/Projects/MV3D/trunk/mv3d/tools/overseer$ python overseer.py
File "overseer.py", line 65, in <module>
File "/home/acer/Projects/MV3D/trunk/mv3d/server/overseer.py", line 38, in <module>
File "/home/acer/Projects/MV3D/trunk/mv3d/server/worldgen.py", line 36, in <module>
File "/home/acer/Projects/MV3D/trunk/mv3d/server/model/octree.py", line 34, in <module>
[demon@demon mv3d_trunk]$ python2 RunClient.py
2011-07-12 13:03:53+0600 [-] Log opened.
2011-07-12 13:03:53+0600 [-] Unhandled Error
File "RunClient.py", line 105, in <module>
go()
File "/usr/lib/python2.7/site-packages/twisted/internet/defer.py", line 1141, in unwindGenerator
return _inlineCallbacks(None, f(*args, **kwargs), Deferred())
File "/usr/lib/python2.7/site-packages/twisted/internet/defer.py", line 1020, in _inlineCallbacks
result = g.send(result)
File "RunClient.py", line 83, in go
conductor.configure(options["config-name"], cf, configfile)
File "/home/demon/devel/mv3d_trunk/mv3d/util/conductor.py", line 266, in configure
svc.configure(svcn, cf)
File "/home/demon/devel/mv3d_trunk/mv3d/client/player.py", line 128, in configure
self.ui = self.renderer.getRendererClass(IUserInterfaceLibrary)(self)
exceptions.AttributeError: 'NoneType' object has no attribute 'getRendererClass'
2011-07-12 13:03:53+0600 [-] Unhandled error in Deferred:
go()
2011-07-13 14:30:00+0600 [-] Log opened.
Known pipe types:
glxGraphicsPipe
(all display modules loaded.)
2011-07-13 14:30:01+0600 [-] twisted.conch.manhole_ssh.ConchFactory starting on 2222
2011-07-13 14:30:01+0600 [-] Starting factory <twisted.conch.manhole_ssh.ConchFactory instance at 0xa0f826c>
2011-07-13 14:30:02+0600 [-] registerWxApp() was not called on reactor, registering my own wxApp instance.
2011-07-13 14:30:08+0600 [-] Starting factory <HTTPClientFactory: https://login.mv3d.com:8080/service/>
2011-07-13 14:30:11+0600 [HTTPPageGetter,client] Starting factory <HTTPClientFactory: https://login.mv3d.com:8080/service/>
2011-07-13 14:30:11+0600 [HTTPPageGetter,client] Stopping factory <HTTPClientFactory: https://login.mv3d.com:8080/service/>
2011-07-13 14:30:12+0600 [HTTPPageGetter,client] Unhandled Error
File "/usr/lib/python2.7/site-packages/twisted/internet/defer.py", line 542, in _runCallbacks
current.result = callback(current.result, *args, **kw)
File "/usr/lib/python2.7/site-packages/twisted/internet/defer.py", line 1076, in gotResult
_inlineCallbacks(r, g, deferred)
File "/usr/lib/python2.7/site-packages/twisted/internet/defer.py", line 1018, in _inlineCallbacks
result = result.throwExceptionIntoGenerator(g)
File "/usr/lib/python2.7/site-packages/twisted/python/failure.py", line 350, in throwExceptionIntoGenerator
return g.throw(self.type, self.value, self.tb)
File "/home/demon/devel/mv3d_trunk/mv3d/client/state.py", line 67, in onLogin
self.client.svc = yield self.client.conductor.getService(service)
File "/home/demon/devel/mv3d_trunk/mv3d/net/client.py", line 748, in getService
pws = yield self.getTempPasswords(sl)
exceptions.TypeError: exceptions must be classes, or instances, not unicode
2011-07-13 14:30:12+0600 [HTTPPageGetter,client] Stopping factory <HTTPClientFactory: https://login.mv3d.com:8080/service/>
acer@acer-tech:~/Projects/MV3D/trunk/mv3d/tools/overseer$ python overseer.pyunkier wrote:i am using archlinux and python 2.7
here is what i got
- Code: Select all
[Player]
type=mv3d.client.player.PlayerClient
# This is the list of available servers to connect to.
# It is also the list that shows up in the connect dialog
servers=pb://alpha.mv3d.com:1999/Player,pb://localhost:1999/Player
# Auto-connect options.
# When enableld, autoConnect will automatically connect to a server
#autoConnect=True
# define which server to connect to (starting with 0 for the first server listed
# under "servers" above
ac-server=0
# The default credentials to use. This is also the initial values in the connect dialog
defaultLogin=admin:pass
# If specified, a pc with this name is automatically connected to upon login
#defaultPC=admin 0
renderer=mv3d.client.ui.panda.PandaRenderer # Here I added this line to it!acer@acer-tech:~/Projects/MV3D/trunk$ python ./RunClient.pyapt-get install python python-dev python-pyode python-cjson subversion python-wxgtk2.8 cvs cmake g++ bjam autoconf automake libtool libxaw7-dev libfreetype6-dev libboost-dev libpcre3-dev scons libzzip-dev libgl1-mesa-dev libfreeimage-dev libxrandr-dev libglu-devUsers browsing this forum: No registered users and 23 guests
