Linux Server Installation
Problems, questions, or anything else related to the MV3D server.
Postby Landry » Sat Jul 19, 2008 9:29 pm
Is there anyone running this on linux? if so can you please post some tips on doing it?
im new to this software obviously and im intrested in using it for a game idea of mine but first i need to get it running.
i can run it in windows if i have to but *shrugs* just curious.
thanks, any help is greatly appreciated.
Landry
Re: Linux Server Installation
Postby SirGolan » Sat Jul 19, 2008 10:26 pm
If you are running Ubuntu Hardy Heron (8.04) it should be pretty straight forward. I made up a Linux install script that's attached to the wiki page. In order to run the client, you'll also need Python-Ogre installed, but that should be easy if you just follow the instructions in this thread. Installing on Debian or earlier Ubuntu releases shouldn't be too tricky, but for other Linux distros, you may have to compile Python-Ogre yourself. That's not an easy task-- at least in my past experiences, it may have improved since I last tried. I will admit that I haven't run the client much on Linux recently, so it's possible there are bugs. You will definitely have to update the plugins.cfg file to reflect where Python-Ogre's plugin .so's are installed. Definitely let me know if you hit a snag and I'm sure I can help.
FYI, both of the MV3D servers that are up are running on Linux.
Good luck!
Return to Server Software
Users browsing this forum: No registered users and 26 guests
