Windows Client Installation
Problems, questions, anything else related to the MV3D client.
Re: Client Installation
Postby multiverseuser » Fri Apr 04, 2008 4:40 am
[original post deleted]
The information found here was not relevent to Client installation
Last edited by multiverseuser on Sun Apr 06, 2008 4:41 pm, edited 2 times in total.
multiverseuser
Postby SirGolan » Fri Apr 04, 2008 5:38 am
There should be an "Edit this Page" button on the bottom of every wiki page. Dunno if you've used Wikis before, but basically, anything that is in CamelCase becomes a link to a page. If you click on one for a page that doesn't exist, you get the option to create it. There's special formatting you can use as well. Trac's Wiki documentation should get you started. The best trick is that if there's a page with some formatting you like, just click edit to check it out. :)
Btw, if you don't have an "Edit this Page" button, I messed up your account permissions.
Postby multiverseuser » Fri Apr 04, 2008 1:25 pm
I just logged in and I do not get the Edit button at the bottom of the page
multiverseuser
Postby SirGolan » Fri Apr 04, 2008 3:28 pm
Hmm.. What happens when you click this link: http://www.mv3d.com/trac/wiki/WikiStart?action=edit
It should either bring you to a page that says "Editing WikiStart" or say "WIKI_MODIFY privileges are required to perform this operation on WikiStart".
I created a test user with the same permissions as you and it seemed to work. Also, maybe your browser was caching the non editable version-- try shift+reload.
Postby multiverseuser » Sat Apr 05, 2008 5:55 am
I see nothing different when I go to the wiki link.
My account is multiversewiki
multiverseuser
Postby multiverseuser » Sat Apr 05, 2008 6:02 am
I edited out all the instructions found in this post in favor of the wiki page,
In order to eliminate the confusion
Last edited by multiverseuser on Sun Apr 06, 2008 4:43 pm, edited 3 times in total.
multiverseuser
Postby SirGolan » Sun Apr 06, 2008 3:32 am
I see the problem with the wiki-- I was adding the permissions to the "multiverseuserwiki" account as opposed to "multiversewiki", have a look now and see if you can edit..
Thanks for the update on the install doc!
Postby multiverseuser » Sun Apr 06, 2008 4:30 pm
The wiki page has been updated with the latest documentation.
Please post any problems found during the installation so they can be addressed.
We probably need a sticky note at the beginning of this topic to guide users
to the client installation page.
Thank you
multiverseuser
Postby SirGolan » Sun Apr 06, 2008 8:08 pm
I've been trying to figure out how to make posts sticky in this version of phpBB. I'm kinda wondering if it's a patch/addon that I don't have.
Postby multiverseuser » Wed Apr 09, 2008 6:18 am
This topic "Client Installation" should be renamed to Windows Client Installation
multiverseuser
Previous
Return to Client Software
Users browsing this forum: No registered users and 1 guest
